Personality Generator icon Personality Generator — Background randomizer that executes timed scripts to add lifelike actions (movement, servos, camera/control) and unique personality to your robot Try it →
Copying Whole Script Collections
Hello Synthiam Support,
Is there a way to copy all of the scripts in a Script Collection skill or another skill and paste them into a different project? How would you go about doing this?
I'm looking for a method to efficiently transfer scripts between projects within Synthiam ARC. Any guidance on this would be greatly appreciated.
Thank you!
Script Monitor by Synthiam
Monitor and diagnose running ARC scripts: view active script labels, statuses, and stop long-running or background scripts easily.
Script by Synthiam
To efficiently transfer scripts between projects within Synthiam ARC, you can use the Merge feature. This feature allows you to combine multiple projects, making it easy to copy all scripts from one project to another. Here’s how you can do it:
  1. Open ARC: Launch the Synthiam ARC software on your computer.
  2. Load Your Primary Project: Open the project you want to add the scripts to. This will be your primary project.
  3. Merge Projects:
    • Click on the Project tab in the top menu.
    • Select the Merge button, which is located next to the Open and Save buttons.
    • A dialog will appear, prompting you to select the project you want to merge into your primary project. Choose the project that contains the scripts you want to copy.
  4. Select Scripts to Merge:
    • After selecting the project to merge, you will be given options to choose which components (including scripts) you want to merge into your primary project.
    • Select the scripts or other components you wish to include.
  5. Complete the Merge:
    • Confirm your selection and complete the merge process. The selected scripts will now be part of your primary project.
  6. Save Your Project:
    • Once the merge is complete, save your primary project to ensure all changes are stored.
For more detailed instructions, you can refer to the official documentation on merging projects: Merge Project Documentation.
This method allows you to efficiently transfer and manage scripts between different projects within Synthiam ARC, ensuring a smooth workflow.
If you have any further questions or need additional assistance, feel free to ask!
