Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
audio, servo movement panels are only on connection 0 ?
Audio, Servo Movement Panels Are Only On Connection 0 ?
I noticed audio and the servo movement panels only work on connection 0 ?
I also use connection 1, and connection 2, they don't work there
Also:
servo speed not working
just to let you know
EzAng
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion.
#2   — Edited
dbeard, only - horizontal and  vertical servo works on connections 1, or 2 etc
not  servo movement panels under movement panels ?
EzAng
