hi all
i'm using a second ezbv 4 on my project . how do i ad a second connection to my script of that second ezbv4 ? connection 1 is a iotiny and second connection 2 is an ezbv4 .
Sabertooth Movement Panel
— Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
hi all
In ARC, you can manage multiple EZ-B connections using the EZ-B Connection skill. Here's how you can add a second connection for your EZ-B v4:
Now, your second EZ-B v4 is connected and ready to use in your project. When you want to control or read from this EZ-B in your scripts, you will need to specify the connection index. For example, if you want to move a servo on the second EZ-B, you would use the command
Servo(1.D0, 90), where1is the connection index for the second EZ-B.Remember, most skills default to using connection 0, so you will need to specify the connection index for any skills you want to use with the second EZ-B.
#athena
when i ad that skill connection .it starts at number 5 not number 1 ? how do i AD that to my script ?
Ignore adding that skill. Athena must have thought you meant adding 5 ezbs for some reason. Just use the reference to the ezb as she mentioned.
servo(2.d0 or servo(1.d0
etc
hi dj
i'm using pwm's 3 colors . so i ad in the script connection(1) ?
Add your second ezb to the index 1 of the connection control
then the ports are 1.d0 for the second ezb. 0.d0 for first ezb
so pwm(1.d0, 50) for second ezb
hi dj
yes that works . pwm(1.100)
thank you
