Speech Recognition icon Speech Recognition — Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence. Try it →
Wifi Connection
Wifi Connection
Hello all,
I just purchased a JD and have it assembled. However, I'm having trouble making a wi-fi connection. Hoping someone can help. I also uninstalled McAfee anti-virus and disabled the windows firewall.
What EZ-Robot or product are you using? (i.e. JD, Six, Developer Kit, etc). JD
Is the battery on the robot fully charged? YES
Does the robot make a startup sound when powered on? Is there a verbal message spoken from the EZ-B v4? If so, you may need to reset The EZ-B v4 YES
What color is the light on the EZ-B v4 and is it flashing or steady? (Flashing Green, steady blue, white, etc) FLASHING BLUE
Are you connecting the device to the WiFi network of the EZ-B v4 by following the video instructions on this page? YES, MY LAPTOP SHOWS ITS CONNECTED TO EZ-B
What error message is displayed in the status window at the bottom of ARC? Press the COPY button on the status window and paste the contents in the forum post. I GET THIS ERROR MESSAGE Connection Failed: System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.1:23 at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult) at EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
If an error appears, some devices take up to 1 minute to detect the ezb - wait 5-10 seconds and press connect again. Note: do not change or modify the IP address field on connection screen. Use the default value. YES, DID THAT, NO CHANGE
If a connection still does not occur, are you certain your device is connected to the EZ-B v4 via Wi-Fi? YES
Have you double checked the wire connections to the EZ-B v4 using the very helpful learn section on our website? Ensuring the black wire if all plugs matches the black side of the ezb connections? Etc... YES
Reset the EZ-B and repeat this procedure if you are still experiencing issues. OK, RESET - NO CHANGE Resetting tutorial can be found here When resetting, does EZ-B speak introduction message as in the video? YES
If still unable to connect, inquire on the Community Forum and paste answers to these above questions. Also provide what device is being used to connect to the EZ-Robot? (model/operating system) eg Windows 8/Samsung Note 3/Android, iPhone 6, etc WINDOWS 7 PRO - DELL PRECISION 7710 LAPTOP
Thanks, Brooks Markert
Rather than changing to client mode - i recommend changing the IP Address of the robot -or- your home network.
Here's what is happening...
  • The default IP address of JD is 192.168.1.x
  • It also appears that your router network is also 192.168.1.x
This means two devices have the same network on different adapters - that causes a conflict. There are two solutions...
  1. Change the network of the router. This can be done by logging into the router's admin console (192.168.1.1) and locating the LAN tab and simply typing in a new address, such as 192.168.2.1 or 192.168.3.1 or 192.168.4.1, etc...
  2. Change the network of the EZ-B. This can be done by disconnecting from your Ethernet and connecting to the EZ-B JD. Log into JD's admin console by visiting 192.168.1.1 and changing the IP address to 192.168.2.1 or 192.168.3.1, etc...
Here's a link with more information for "dual connectivity": https://synthiam.com/Community/Tutorials/80
