EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
What Is The Ezb Serial Terminal Used For And How Do You Use It?
Hello,
Just wondering what the EZB Serial Terminal is and how you would use it? I assume the PC Serial Terminal in ARC allows you to view serial data coming into and going out of the PC Serial Port. Seems it takes the place of hyperterminal, etc. The use of EZB Serial Terminal is not obvious to me. I have an idea but I don't think it is correct.
Using the EZB Serial Terminal it seems that I could initialize the uart port0 with script control and then write data out the uart port in the same script and it should appear in the EZB Serial Terminal window? Would this be correct or not? Thanks Much !Rick B.
#25
You are one of the most patient new users I've ever seen:). Got that going for u!
#26
Hello DJ,
Yes and I never give up. May take me longer than some but I will get there. Again want to thank you and all the others that have helped me out and for the very quick responses. The best support system around not to mention the awesome hardware/software products ! Rick :)
#27
Hello DJ,
Really looking forward to the new controller and other software/hardware products coming out this year ! :) Rick
