What has the end of this battery?
— Edited
4 Participants
Frequency Detector
— Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback.
It would appear that the battery has dual 2.1 or 2.5mm dc connections. One jack is used to connect to the EZ-B, and the other is where the charger connects to.
Thanks!
I guess ill buy this end for the ez-b. Will wire a mini dean to the connector.
Or just wire a mini deans directly to the battery itself... cut the barrel plug off the battery and solder a mini deans to it...
Doesn't the V4 come with an adapter? I'm sure I read it does...
I remember that too. Is it this thread at post #35?
Development kit only.
