EZ-SLAM icon EZ-SLAM — Creates a map in a global variable; proof-of-concept SLAM visualizer (very experimental). Try it →
Nope...ez robot only makes a 5V version... What do you need 3V for?
RR
from joch are 4.7 volt.i need 3 volts.i got led blinker with swiths. i thought to build in the dome.
Gibraltar
@nomad18.08 the white digital pins (signal) are 3.3v just connect black to any ground and positive to a white digital pin and add a PWM control that's how I control small LEDs
BBORASTERO
no need for regulator then.
thanks
bborastero
that works great.
Wooo! It's twinkly at nomad's
dj
it will look good on six and galapagos bot.
