Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Virtual Robot Error?
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.ArgumentException: Parameter is not valid. at System.Drawing.Image.get_RawFormat() at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawImage(Image image, Rectangle rect) at System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1002 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
FFMPEG Assembly Version: 2013.1.16.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/FFMPEG.DLL
aForge Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/aForge.DLL
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
y2vg35vp Assembly Version: 2013.2.17.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
NAudio Assembly Version: 2013.2.11.0 Win32 Version: 2013.02.11.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/NAudio.DLL
EZ-QRCode Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-QRCode.DLL
WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.298 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
This is the error. What is it telling me to do?
Hey, new to the board here. I am receiving the same error. I couldn't find if this thread had been moved to the ARC thread somewhere... Any word on how to fix this?
BTW, i am trying to add an image to the Virtual Robot control. when i click change image, i select the picture i want to add, this error comes up with both Bitmaps and JPG's... tried multiple images.
EZ-Builder Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///G:/Network%20Software/Server%20Software/EZbuilder/ARC.exe
EZ_B Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.00 CodeBase: file:///G:/Network%20Software/Server%20Software/EZbuilder/EZ_B.DLL
FFMPEG Assembly Version: 2013.1.16.0 Win32 Version: CodeBase: file:///G:/Network%20Software/Server%20Software/EZbuilder/FFMPEG.DLL
System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
y0lgpqgu Assembly Version: 2013.3.18.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
ARC Examples Assembly Version: 2013.3.18.0 Win32 Version: 2013.03.18.0 CodeBase: file:///G:/Network%20Software/Server%20Software/EZbuilder/ARC.20Examples.DLL
pqmjyvca Assembly Version: 2013.3.18.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
I can only assume it's on "the list" if it hasn't been fixed yet.
Reading between the lines somewhat I can only assume there will be a major release for ARC soon, this may have the fix in it. Since we have not received any updates to ARC lately I'm going out on a limb and guessing that minor updates are on hold until the major release is done... but don't quote me on that, it's purely speculation.
I haven't been able to reproduce this error:( ... Even when I used the BMP that you shared on that thread - It works great for me. What OS are you running?
That's odd, I run Windows 7 ultimate 32 bit.
I'll try it on win 7 64 bit and win 8 when I get chance to see what happens.
You know what? It might be a RAM related issue. I know you may have a billion GB of ram - but ram works by Pages in chunks of memory large enough to hold things. Anyway, the image you posted is HUGE. Like, really big.
I would recommend shrinking the image down to a reasonable size, of say 1024x768 or something. Then try Virtual Robot:)
All 3 of my Windows PCs do the same thing. Windows 7 Ultimate 32 Bit, 4Gb ram (3.25Gb usable), 2.9Ghz dual core. Windows 7 Enterprise 64 Bit, 16Gb ram, 3.5Ghz 6 core. Windows 8 Pro 32 Bit, 2Gb ram, 2Ghz dual core.
All using a much smaller image too (tried a few different images too but all with the same result).
It's not a problem to me, the virtual robot takes up too much of my screen real estate but it's odd that it happens on all of my PCs but not for you. The Windows 8 one is pretty much a virgin machine with only the addition of ARC and Chrome. The Windows 7 64 bit is near virgin too, with just work apps (autocad, office, adobe CS) and ARC.
#16
The same thing happens with that image.
I started the Problem Step Recorder in W7 to record it all if that gives any further info, it's attached. problemsteprecorder.zip
