Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
Virtual Robot Error?
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.ArgumentException: Parameter is not valid. at System.Drawing.Image.get_RawFormat() at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawImage(Image image, Rectangle rect) at System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-Builder.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1002 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
FFMPEG Assembly Version: 2013.1.16.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/FFMPEG.DLL
aForge Assembly Version: 2013.2.17.0 Win32 Version: 2013.02.17.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/aForge.DLL
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
y2vg35vp Assembly Version: 2013.2.17.0 Win32 Version: 4.0.30319.1001 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
NAudio Assembly Version: 2013.2.11.0 Win32 Version: 2013.02.11.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/NAudio.DLL
EZ-QRCode Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/EZ-Builder/EZ-QRCode.DLL
WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.298 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
This is the error. What is it telling me to do?
When providing an error log, please include what you were doing to cause it. Additionally, the website forum is split into categories for different subjects. You have this posted under "hardware". This is not a hardware issue. It is being moved.
We notice you post almost everything in "HArdware". Please begin posting in appropiate categories:) Thanks
I was adding the picture to the virtual robot when it happend. i used the pic of the wall-e on your build now ad.
really? i swear i posted this under bug report. Sorry about that. I have been getting around a bit more lately
That error looks like it wasnt an image file. Are you sure it was a picture and not an HTML file? I can try and see if I can recreate it:)
Update: Got a photo. The pic shows up when i tell it to only show supported images.
Can you please clarify? What do you mean by supported images? And if you got the pic to show up, why is there an error message?
@DJ, I replicated the error... by choosing a jpg 3.25Mb size, 4608x3456.
I've uploaded my image here
My error message was
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2013.2.11.0 Win32 Version: 2013.02.11.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/ARC.exe
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
EZ_B Assembly Version: 2013.2.11.0 Win32 Version: 2013.02.11.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/EZ_B.DLL
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
FFMPEG Assembly Version: 2013.1.16.0 Win32 Version: CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/FFMPEG.DLL
aForge Assembly Version: 2013.2.11.0 Win32 Version: 2013.02.11.00 CodeBase: file:///C:/Program%20Files/EZ-Robot%20Inc/ARC/aForge.DLL
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
It does the same for smaller images also (tested 3 smaller jpgs of schematics)
the pic shows up in the file browser when i have selected it to show only supported images.
