Benchmark icon Benchmark — Diagnose EZ-B connection speed and reliability; benchmark ADC read rates (4-70/sec), reveal flood-control effects and optimize data throttle. Try it →
Using The Jd Kit, What Other Projects Have People Built?
DJ, you had asked me if I would like to have other projects to choose from on ARC software. Well I discussed this with my kids, and the first thing they said was they would like to build a robot arm with camera on the end. I think I saw somewhere on here where you may have done that.
So to answer your question, if there were more projects to choose when using ARC besides just the normal JD robot, I think that would help a lot.
Also if anyone has built other items from the JD kit, please post some links so i can review with the kids.
PS: DJ get off the table! :D
But are the 12 connectors an "Extension Cube" or an "Extension Block" or something else. Trying to be specific so I know exactly what comes with that base unit and what else I would need to order.
They are connector slots on the body itself. Not cubes or extensions. Cubes, extensions, servos, or anything else with a clip and play clip can connect to it.
I changed the wording to "Connections" instead of "connectors" to clarify - thanks for the heads up:)
You do not necessarily need the hexapod body - if you will be disassembling JD, I would recommend using his body:). The children can get creative and use a hot glue gun with popsicle sticks to create a base.
The plastic of the revolution robots will allow hobby grade (low heat) hot glue to peal away. I would avoid getting the hot glue in the connectors, because that might not be fun:)
You can also draw on the plastic as well - even with a sharpie! It simply washes away with whiteboard eraser spray. We draw on ours all the time...
@69developer.
I was just reading through your thread and thought I would offer up a couple of ideas for yourself and your children. Just to add to what DJ mentioned above, some time back (before I discovered EZ-Robot) I made some robots with my niece and nephew when they came to visit, using some old R/C cars and lots of plastic containers and cardboard. Below are a few pics of what we came up with...
Made using an old mini vacuum cleaner, ice cream container, cardboard, an old MP4 player, and foam.
Sorry for the bad photo quality, it's the only picture I have. He was made using printing paper, cardboard, drink bottle caps, and a broken clock radio.
This one never really go finished as the Dalek took over. He was made of a cardboard cell phone box, plastic milk bottles, plastic biscuit box, ice cream container, and cardboard.
The Darlek is my favourite (and a bit of self indulgence), and made completely of recycled parts. Cardboard, old marker pens, peace's of foam, deodorant can lid's, old wireless web cam, and various other bits and peaces. Dalek BOB Instructable
All the bits we used were rescued from my recycle bin. Empty milk bottles, ice cream tubs, breakfast boxes, R/C cars and tanks with their servos, the only thing I really paid for was for the paint. So to get back to your original question "Using The Jd Kit, What Other Projects Have People Built?", as I said, these are not EZ-Robots (although I thinking of rebuilding the Dalek using a development kit), but using your JD (or any of the other Revolution bots or Parts) you could consider doing something similar. For example...
Remove the camera and RGB display from the JD head to put in your own robot head and use the servos to make your own pan and tilt neck,
Use the servos as arms and make paper or cardboard limbs to cover,
Make a single manipulator arm,
Use lever servos to act as actuators to deploy and retract things like a torch,
Use servos to open flaps on a robot body to reveal his insides,
Order and add a couple of modified continuous rotation servos and wheels for a drive base,
the possibilities are endless. And using sturdy plastic containers, small holes can be cut (adult supervision of course) for EZ-Bits to connect to.
This way your son and daughter can use their creativity to make something they would really like, have fun with the building process, and a sense of achievement with what they built, all using the JD robot and items you already have laying around the house. My sisters kids loved doing these projects, and when they got bored with the robot, they would make a new one with a different design using the same servos ect. Cheap, fun, educational, and great to see what the kids come up with.
I'm currently making a project up-cycling items and using the development kit, scorpion kit and a few extra servos and sensors, which I will showcase in a couple of weeks. Anyway, I hope this have given you some ideas of something yourself and the kids could do together using what you have, and maybe you could build a robotic arm using similar methods.
Hope some of this helps and gives you some ideas what you could do with your JD.:)
The robot arm the EZ-Robot has on their website in which the Intern helped with is something the kids are interested in doing. DJ, do you have detailed instructions similar to the JD robot to make this robotic arm? I'm gonna try and let the kids do this one by themselves.
