Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Trouble Hooking Up To Ezb4
Ok, I know it is not EZB4s problem.
First let me tell you my setup. I have EZB3 hooked to COM9 on my notebook connected to my robot on port 0 which is bluetooth.
I have an EZB4 connected to Port1 which is wireless.
I have VNC coming from my desktop which controls the Sunshine Robot Mimo Monitor touch screen.
In the past, I I simply turned on my notebook which fired up the VNC network. I then activated the VNC on my desktop so I could talk to the Mimo monitor screen. This all worked good and I started ARC and operated my robot.
Now, when I try to hookup the EZB4, I don't see it in the wireless connections list. There are many, but not it.
I am following D.J.s steps:
  1. connect V4 in wireless setup
  2. then connect in ARC.
This should be a piece of cake.
what it does is quickly go back to the Connect dialog and ask if I need to see the tutorial which I have seen many times.
I have a tendency to make things way more complicated than they are. My network is interfering with my EZB4. I think they BOTH have the same IP address. So when one is working and you try to connect, it kicks one or the other off the network.
I don't really know how to fix this. I ultimately want to have 3 v4s and 1 v3 hooked up at once.
I tried a spare one just out of the box. It does the same thing, it tries to connect and then it goes back to connect button. Help.
