Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Not that I know of nomad. usually its what you see is what you get with ez-robot.
ah okay.thanks blush
You might be able to find someone who modified the servo on the internet to be transparent.
Tryin' to make an invisible robot are ya' nomad? :P
haha no,sometimes am not realistic.i always say think before you cut. i was thinking on the robobuilder servo's.:)
If its the one I think you are talking about Tech... I think it's just a DC motor in a servo shaped casing... It will be continuous rotation then...
then jd will be rapidly go bonkers as dj says haha
