Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
i use the filering.withs pic you talking about?
#42
I'm pretty sure Alan is talking about the Engenius pic in the last post. Like he said this is where you list each EZB so it will always look for that number and connect. I don't use this section at all and I have no issues connecting. However I have them listed in my main router instead. Perhaps with you problems you should have them listed but maybe you shouldn't fool around with this until you funally connect to the EZB. Once connected you can fill this out.
Also in your first pic it looks like your setting up the network connections on your cabled connection not your wifi. Again, I have nothing listed in the section you point to. I have both top and bottom buttons set on "Obtain DNS Server address automatically".
that is cause there is a lan wire connected to my destop wifi. the issue is on the laptop.i dont have a clue withs ip and mack number it is. as long the laptop doesn find the engenius nothing will connect. so the last pic means ip and mack number from laptop?
#44
The last pic is the IP and Mac numbers of anything you want to connect to the Engenius. I'm weak on networking but I think all devices like EZB's and laptops listed in Mac Filtering (when enabled) will connect and everything else will not.
Try disabling Mac filtering in the engenius.
i dont think mack filtering is checked but i will see for sure.
the pc man did a new config and all works,except one problem. the speed drops avery 5 a 10 sec with half speed. any idea what can i do?
#47
Outstanding! Your back in the robot business! !
Can you try to explain the speed issue a little better? Do you have a good strong wifi signal for the ezb? Is there anything running in the background on the computer that may slow it down. Antivirus, vedio, Internet browser activities, any thing that may be useing the wifi connection?
hi dave
no i try it whit nothing els then ARC. i got some more info for my pc guy.but its possible someone is using my , acces point from far distants.the engenius signal drops avery 5 sec from 130 mbps to 62 mbps and then ezbv diconnects.
