Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Sorry, I can usually figure out what you are trying to say, but I have no idea what the last thing you said was.. "smiles up"? What does that mean?
Anyway, if you added the MAC address to the Engenius and it still can't connect, you probably entered the MAC address wrong. Need to temporarily turn off MAC filtering and see if you can connect, then add the address to the filter and turn the filter back on.
If you can't connect to the web address of the Engenius, then it will never connect because you won't be able to add the address to the filter or turn off the filter.
that was a typo
i can see the mac adres in internetconnections and that what i put on engenius. after that for some reason i cant get on the web page of engenius.
never mind thanks alan,am quiting today am really start to hate this.
is the web page of the engenius not responding, or is it rejecting your logon? If it is not responding, try rebooting it. If it is rejecting your logon, make sure your caps lock key is not on since user names and passwords are probably case sensitive. If still not letting you log on, will probably need a factory reset, which would suck since you'll have to re-enter all of your EZ-Bs and turn the filter back on since your neighbors hack your system...
Maybe Dave C or one of the other people who have helped you remotely will have some other ideas before we take that drastic step.
i allredy rebooted and take out the wallsocket for 10 sec. i cant get on the webpage from engenius. and funny is my destop and laptop says engenius is connected.
i get time out.
hmm... And it is clearly working since you can get on the Internet.
You other EZ-Bs are still working?
none robots will connect.
#15
Hmm - could someone have backed the ingenious? If the password doesn't work...
i dont know.but i saw the engenius fast broadcasting the led was blinking very fast
