On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
got error message.
steve g
1 bad charger 11.20 volt normal 12.00 volt the fourth batt is death ,one in jd .seems problem i gess the batts, are puchered in the jd's robots.got 1.15 hour for charging the other and , green led goes out.
my apolegies for making two topics.
Twitter
If so, select the member who helped you and leave a polite comment to thank the member for helping down below. If your question has not been resolved yet, do not select anything from the dropdown.
it says solved ai support bot?
it was solved by steve G. thank you.
