PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Greece
Support For Ez- B Ve
Hello EZ-B,
i have a V3 controller for my project, and i and i can not connect to the port from today. May i ask if it changhe something for the EZ-B VE controller?
i have read the post that it is no longer supported by EZ -B. But all this days i had no problem with the controller v3!
Friendly Sakis
Good Morning...,
some help please..!
i can't connect the V4 controller with a serial port!, i made all the changes as the the manual tutorial write.
i use the Baud Rate: 921600 but no connection
i use the follow usb serial converter:
https://www.ebay.ca/itm/USB-2-0-to-TTL-UART-5PIN-Module-Serial-Converter-CP2102-STC-PRGMR-Free-Cable-Top/291816553699?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20160608112848%26meid%3D92099dfe09404dbc80d97e8389141200%26pid%3D100623%26rk%3D4%26rkt%3D6%26sd%3D310511987503
Any Help confused
