Greece
Support For Ez- B Ve
Hello EZ-B,
i have a V3 controller for my project, and i and i can not connect to the port from today. May i ask if it changhe something for the EZ-B VE controller?
i have read the post that it is no longer supported by EZ -B. But all this days i had no problem with the controller v3!
Friendly Sakis
Mpravo Richard!, thanks a lot .
Hello again....,
may i ask if i can use the serial Port for USB Connectivity? or just the Camera Port?
You need to use the camera port unfortunately...
The manual tutorial that was given to you in an earlier response contains the instructions, and the only instructions.
If your robot is connected via serial, there is no need for the ezrobot camera. This is because your computer is obviously close enough to use a USB camera.
ok, thanks alot for the clarification DJ Sures and Richard.
