DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Speech Recognition
Hello, I just got my new computer and I am finally running Windows 7. To my dismay I spent the entire day and I can't get speech recognition to work. I have read all the turorials and searched and read everything on the forum to no avail. Language, default, Windows SR off, tried everything. Any further suggestions would be greatly appreciated.
Did you try with board 0 connected?
Install ARC on another PC and check that works then look for diffrences between the 2 setups
I will try both ideas later today. Looks to me like I may be returning the new computer.
Netherlands
Bookmaker. Do you have the webcam from Konig in your robot ?
If so > look if your recorded mic is that one.
I installed w7 on my laptop and installed speech software and disable the start up) Next day i had my brand new konig wireless cam plugged in and installed. No speech recognition anymore........ after almost an hour i disconnected the cam and tried it again an whoopy it worked again.
if not > I had the same problem on my HP dc5800 tried everything i even reinstalled windows 7. and it is still not working, skype works and speech to word also....
So i installed on my laptop a toshiba and at first it did not work because i let the speech service on. turned it off and it's working
end if >
You are certain the microphone input VU meter is displaying your voice level?
#15
GeeeeeeeZZZZZZZZZ, I must admit I don't know what I did but once I upgraded to V13 the Speech recognition started working. Thanks to all for the great direction. I be one happy bookmaker.
#16
Well! Seems that v13 is a very lucky number after all:D
