Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
Smoothing jaw via WebSocket Client
Smoothing Jaw Via Websocket Client
I’ve got an EZ-InMoov Robot Head wired to an EZ-B over WiFi, with the jaw servo on D5 and neck pan/tilt on D0/D1. I’m feeding lip-sync amplitude from a local WebSocket server (ws://192.168.1.50:8080) into the WebSocket Client skill. The Response Variable is $ws_amp (0-100 text), and the Response Script maps that to a jaw angle. I also added a Slide Script named "Lip Smoothing" that writes into $lip_smooth (range 1-10) so I can tweak the easing live, and the Bonus Button snaps the jaw to neutral for testing.
The jaw moves, but it chatters like crazy and sometimes lags behind the audio. Debug shows the WebSocket pushing ~40-60 messages/sec, so the Response Script gets hammered. I tried ServoSpeed(D5, 2) and even Sleep(30) inside the Response Script, but that either doesn’t help or starves the socket and I start missing updates. Turning Debug off reduced CPU, but the jitter remains. I also tried casting to ints and clamping the range, plus a naïve blend toward target:
# WebSocket Client Response Script
$amp = ToInt($ws_amp)
$target = 40 + (($amp / 100) * 45)
$current = GetServo(D5)
if ($lip_smooth < 1)
  $lip_smooth = 1
endif
$next = $current + (($target - $current) / $lip_smooth)
Servo(D5, $next)
Neck servos on D0/D1 are fine because they’re not being spammed like the jaw. I’m thinking the right pattern is: let WebSocket Client only update a global target variable, and run a separate looping script at, say, 25-30 Hz that eases the servo toward that target using $lip_smooth from the Slide Script-but I’m unsure of the cleanest ARC way to wire that without blocking or racing the Response Script, so what’s the recommended approach to handle highfrequency WebSocket Client updates for a smooth D5 jaw on an EZInMoov using a Slide Script for smoothing?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Slide Script by Synthiam
Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press.
Websocket Client by Synthiam
WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status.
Yes - the recommended ARC pattern is exactly what you described:
  • WebSocket Client should only store the latest target amplitude
  • A separate loop script should drive the jaw at a fixed rate
  • Don’t move the servo directly inside the WebSocket Response Script
That is the clean, proven way to handle high-frequency input in ARC. If you try to animate the servo inside the WebSocket callback, you’ll get exactly what you’re seeing: chatter, lag, and dropped responsiveness.
Why your current approach jitters
Your WebSocket is sending 40-60 updates/sec, which means the Response Script is being fired constantly. If that script:
  • reads servo position,
  • computes easing,
  • moves the servo,
  • and especially if it sleeps,
then you’re mixing network reception with motion control. That causes timing conflicts and backlog.
Better architecture in ARC
1) WebSocket Client Response Script
Make it do only this:
  • parse the amplitude
  • save it to a global variable like $jaw_target
Example:
var amp = parseInt(getVar("$ws_amp", "0"));
if (isNaN(amp)) amp = 0;
setVar("$jaw_target", amp);
If you want to clamp it:
if (amp < 0) amp = 0;
if (amp > 100) amp = 100;
2) Separate jaw loop script
Run a loop script from a dedicated skill button, init script, or startup script. This script should:
  • read $jaw_target
  • read $lip_smooth
  • smooth toward the target
  • update D5 at a fixed rate like 25-30 Hz
  • avoid blocking the WebSocket
Example JavaScript:
var jawPort = d5;
var minJaw = 40;
var maxJaw = 85;
while (true) {
  var amp = parseInt(getVar("$jaw_target", "0"));
  var smooth = parseInt(getVar("$lip_smooth", "5"));
  if (isNaN(smooth) || smooth < 1) smooth = 1;
  var target = minJaw + ((amp / 100) * (maxJaw - minJaw));
  var current = Servo.getPosition(jawPort);
  if (current < 1) current = target;
  var next = current + ((target - current) / smooth);
  Servo.setPosition(jawPort, Math.round(next));
  sleep(33); // ~30 Hz
Important note
Your example uses GetServo(D5) and Servo(D5, next) - that’s not the preferred ARC approach. In ARC JavaScript, use the official API:
  • Servo.getPosition(d5)
  • Servo.setPosition(d5, value)
Also, don’t use Sleep(30) in a way that blocks the WebSocket response path. Use the separate loop instead.
Even better: add a deadband
To reduce chatter near small movements, only move the jaw if the difference is significant enough:
var jawPort = d5;
var minJaw = 40;
var maxJaw = 85;
var deadband = 1;
while (true) {
  if (Math.abs(next - current) >= deadband) {
  sleep(33);
  • Response Variable: $ws_amp
  • Response Script: update $jaw_target only
Slide Script skill
  • Variable: $lip_smooth
  • Range: 1 to 10
  • Bonus button: set jaw to neutral or set $jaw_target to 0
Separate script skill
Use a script skill to continuously animate the jaw.
If you want it even cleaner
You can also have the WebSocket script write a latest target only, and let the loop script do all servo math. That keeps the WebSocket handler extremely lightweight.
On your neck servos
You’re right that D0/D1 are fine because they aren’t being hit at the same rate. But if you later want head movement to also follow streaming data, use the same pattern: latest target in one script, motion update in another.
Best practice summary
  • Do not move servos directly in the WebSocket response
  • Do not sleep inside the response script
  • Store target values only
  • Use a timed loop script to interpolate toward the target
  • Use Slide Script for live smoothing control
  • Add a deadband to stop micro-jitter
One more question
What do you want the jaw behavior to feel like overall:
  • robotic and snappy
  • natural speech-like movement
  • or very smooth/cinematic
That changes the best update rate and smoothing math.
If you want, I can write you a complete ARC JavaScript solution using:
  • WebSocket Client response script
  • Slide Script integration
  • jaw loop script
  • neutral reset button
