Camera Device icon Camera Device — Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts Try it →
Single Connectors For Multiple Servos?
Hello All
I need some advice. My B9 robot has multiple servos running a variety of components. Occasionally I need to disconnect everything to do some maintenance. In order to avoid disconnecting each servo line I was thinking of using something like this (see below) to consolidate my connections.
Seem reasonable?
Thanks,
Daniel
BTW any suggestions on other methods would be great :-)
That would work fine as long as you don't get them backwards and there all separate. Could you give a link?
Thanks Technopro
Do you mean a link to the vendor or my project? I think the vendor was an RC hobbyist company. I don't have an image of my build up. Essentially the H bridges are the challenge. Multiple signal wires to the EZ board. I think the solution above will work.
Daniel
@Mulberry ...Technopro has a very good point . White out would make a good paint on designator!:)
