Resolved Resolved by Athena!
Should I Upgrade robots computer to Windows 11?
Should I Upgrade Robots Computer To Windows 11?
I've been running ARC on Windows 10 Home edition with no issues on an onboard mini computer mounted on my robot and connected through USB to three EZBs. It's been optimized and stripped down like suggested by @DJ here on this site using his Windows 10 Storage & Performance Tips here: https://synthiam.com/Support/Tips-to-Make-a-Robot/free-space-with-windows-10 . I keep getting warnings to do the free upgrade to Win 11 because support is going to stop. Also Win 10 keeps updating it's self even though I've tried to turn this off like stated in the above Performance Tips. It's annoying as each time this happens my robot stops working until I underact. Should I let it update to Windows 11 and if so will ARC run as good or better or worse then now with Win 10? I'm sure if I do I'll need to optimize again. Will the above Windows 10 Performance tips also apply to Windows 11? If it helps my mini computer is a Beelink Mini PC, EQ14 Intel Twin Lake N150(up to 3.6GHz) 4C/4T, 16GB DDR4 RAM 500GB SSD.
For the record, In the performance tips above @DJ says to turn off Windows Update. However each time I do this Update comes back to life like a horror film zombie. This is why I keep getting these update notices. I've researched a good way to permanently disable the update and it seems that Windows 10 Home version is missing a couple things that would let me preform one of the sure fire ways to do this. Windows 10 Pro does have it but MS support is ending for 10.
Thanks for your advice in advance.
#17
I time my mini PC Today on tiny11, KAMRUI GK3Plus Mini PC, 16GB RAM 512GB M.2 SSD Mini Computers,12th Gen Alder Lake N95 (up to 3.4GHz) Micro PC, 2.5''SSD, Gigabit Ethernet, 4K UHD, WiFi, BT, VESA/Home/Business Mini Desktop Computers.
Only took 17 seconds from the time I push the power button and auto log into Windows Tiny11.
