Cognitive Emotion icon Cognitive Emotion — Uses Microsoft Cognitive Emotion cloud to analyze camera images, returning emotion descriptions and confidence for speech/output (requires internet). Try it →
Seems Sometime Site Is Slow
Lately Only, sometimes slow. And, a lot of missing links. Page not found, etc.
Not the way it used to be Lightning fast. I am running at 100mps and my speed tests show it. I figure that there was a problem and you are working on it.
This is not a complaint. Also, this does not require an answer. It was just so you would know.
The html code for the website is intense so I wouldn't be surprised that a computer may take some time to decipher it.
It's not that intense and nothing has really changed recently. My guess is either high server demands/loads or some work being done on the back end which causes intermittent speed issues.
I did notice it running a little slow the other day but it's been fine since. Is it just EZ-Robot that is slow or do you suffer on other sites too? Have you tried it on other PCs too with the same results? It could be something as simple as back end work to the site or could be something more nasty such as malware.
What missing links?
Mostly in the showcase. I clicked on many of them that I got page not found.
The showcase is pretty much the same as the forum. Either it was while the site was down (for any reason, not that I've noticed it's been down lately) or your internet dropped while you were browsing the showcase.
Is the site still slow for you? I can say it has been perfectly fine all day for me, so for the last 12-13 hours. If you have experienced problems I'd suggest you check your internet and/or your router. Some routers will keep a log of problems, my money would be on an issue there rather than on the site.
Ireland
I found web site quite slow too a number of days ago ,went off to work tried again on work pc same problem gave up trying to access, A few hours later when I logged on again all ok and have had no issues since. That was possibly friday \ saturday last wk
@moviemaker, the website undergoes updates , refreshes and things like that when @Chrissi makes changes. You will want to delete your cache and cookies , logout and login agian for the best performance.
