Soundboard (PC) icon Soundboard (PC) — Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate. Try it →
Germany
Google+ YouTube
Rotation Servos
Hello Dj, i have a Problem with my Rotation Servos. I have these servos few years ago when you ordered along with the EZB-V3 and never used. Now I want to build a small robot and use these servos. Please look at the video, then you understand my problem:
https://youtu.be/wwaaWDcvSrg
I have the problem with all 4 servos and even with two boards EZB-V4. If this is a software error, or have you then a batch of defective servos? The EZB-V3 I have not so I can not test the servos so.
Thank you
  1. You can't use those servos with the ez-b v4 or they will be damaged immediately due to the 7.4 volts
  2. It looks like the screws are on too tight or the wheel is stripped
Germany
Google+ YouTube
Hey DJ, many Thanks to you, the problem was actually the screws on the wheels.
Sometimes one is just stupid. Sorry that I bothered you about it.
Because of the tension, let's see how long the servos join if you are broken I buy just new.
Is there a problem with the 7.4 V even in the normal servos I then purchased from you? Or they are to use the EZB-V4?
@lizpoir The regular ez robot servos are ok with 7.4v so don't worry...:)
I expect them to burn out at any time, but I have been using my old rotation servos from the v3 dev kit with a v4 and a 7.4v LiPo (and earlier with a AA six pack) without a problem. They go pretty fast:) and I only run them a few minutes at a time, but so far they haven't burned out.
Germany
Google+ YouTube
Thanks to you all
Germany
Google+ YouTube
Hello DJ, It certainly was coincidence that it worked when I screwed the wheels loose, the problem still exists. Even without mounted wheels to run the servos not right.
