Touch Path icon Touch Path — Sketch paths with finger or mouse and set turn/move speeds; interactive, educational demo of timing-based, sensorless robot navigation and limits. Try it →
@kamaroman68 Sorry to hear that... Not sure what you are so upset at... I do remember you as being very thinned skinned around here... But really don't you think you are over reacting a little bit?... Not posting here only hurts you my friend....
I promise you my posts had absolutely no malice whatsoever in them... Try not to see so much negativity in posts. Maybe I am a bit sarcastic and ironic, but I am never outright discourteous...
Have you tried rebooting? re-downloading and reinstalling ARC? Re loading your project.... If I had a nickel every time windows caused an issue with software I was using... well you know the old saying...:)
You know I have my share of head scratching issues with ARC. It may seem like I am defending ARC just because I believe in it... Well, yes I do... but mostly because when encountering a problem that I thought for sure was an ARC bug it usually turned out to be something I did... So I am reluctant to post my issues because as I mentioned 99.9% of the time it was something I did or changed or whatever....
@kamaroman68
Steve had something very similar happen last week. In trying to determine if one of the project objects was at fault he imported his project into a new project and everything worked. Something had clearly become corrupt in the original project file. I don't believe it coincided with an ARC upgrade, but might have.
Anyway, importing your project objects into a new project might be worth a shot.
Did you keep a copy of the previous release you can try to revert to? That would be another good troubleshooting method.
Kam, if you post the project, someone or myself will test it
