Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
No, connection information should be maintained without power while you wait for the new batteries, and servo calibration doesn't have anything to do with the power supply.
thank you alan
@nomad... swapping out batteries is the equivalent of turning JD off with his switch, both cut power to the robot.... All servo settings are saved on your computer, not the ezb...
sorry late replay rr
am i lucky then.
