RGB Animator icon RGB Animator — Create custom animations for JD Humanoid's 18 RGB Eyes LEDs via I2C - per-LED color frames, transitions, pauses, scripting and real-time preview. Try it →
Rad 1.0 Mechwarrior #2 Nerf Darts And Airsoft Guns
This is the second outdoor fun entry level mech warrior. This is following begginer level competition rules from mech warriors.com which is a competition ran by trossen robotics. Rules indicate the robot must have a torso and a first person view camera in the torso or head following the ideal that is where a pilot would be if the robot was built to real life scale. Then you can remotely control the robot against other robots in a real life video game! The first robot has already been started and is 80 percent done and my little sister was jealous and she wants her own robot to play with the guys. Three competitors should be more fun so three ez robot cameras are in the way and servos for their gun arms.
#41
Yea original controller. No reason to spend more money to keep original functions.
#42
These are the motors I bought. Im crossing my fingers they are similar to omnibot motors so maybe I can upgrade the rad 2.0 motors.
#43
I bought a couple spare rad 2.0 robots to cut up their base so I could have 4 motors and 4 gearboxs . If thats too difficult I could do the mod I did with the omnibot 2000 gearbox and have two motors mounted agianst one input gear. I would rather have true 4wd powering the tracks though. Im also thinking about modifying the position of the idler wheels so that in the event of track derailment the robot could still move on flat surfaces by the 4 drive wheels.
It's pretty hard to derail those RAD tracks. I think you can leave the idler wheels as they are. However, I do like modding the two bases together like you show. A little fiberlass should fix that up pretty well.
#45
Ok the motors came in. Here is a side by side picture. These motors must be 10 times stronger wow. They feel like they have tons of torque and lower rpm range. Just what you want for tank base;).
