Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Questions!!! Please Help!
Hi I finally received my robot kit but I have a few problems. First of all, all of the standard servos don't work. The continuous rotation servos are fine but not the standard ones. I could hear something in the servo but it would't move. please help me! It is stressing me out! stress I also have a second problem. The battery pack, as I turned it on it quickly became incredibly hot. It even melted the plastic. I don't know what went wrong everthing else was fine. Please reply I am running out of options. right now it is peing held up by electrical tape, but I want to know what caused the problem. confused
We had a bad shipment of servos from the factory. Contact Us with your order number and we will send out replacements:)
Don't worry. D.J. will make it right. There have been a large group of bad servos going around. Not just from D.J. but from all manufactuers. He will make it right. Just be patient.
Mel
Sorry but I don't know what a order number is. Can you please tell me.
Never mind I know what it is. Just found out.
Also thank you DJ Sures for the info, and thank you MovieMaker for the confidence.
