Hi,
I am having problems with the JD robot's left foot/ankle servo. It doesn't seem to move as freely as the others. I first noticed when having the robot walk. When I manually try to move it, it feels stiffer than the other servos. Is this just a bad servo that needs to be replaced or are there any tricks that a I can use to fix it myself?
Thanks
Usually a servo either works or doesn't work. In this case, it sounds as if the screw holding the ankle onto the servo may be too tight. This would prevent the servo from moving freely.
Because the gearing inside of a servo is a high ratio, that increases the ability to "feel" if a servo is stiffer than another. The metal gears internally convert the high speed motor into high torque output. So, when you turn the shaft, you are essentially turning the gears in a direction of a ration that was designed for the opposite direction.
That being said, because a servo either works or doesn't... I would assume the screw may be too tight holding the ankle in place. That is extremely rare because we designed the components to not touch each other even when the screw is tight - however, plastic does have a lot more flexibility
A servo motor moves until it reaches the specified angle.
Also, keep in mind that JD doesn't walk perfectly straight due to slipping a little on the floor. This is quite normal for humanoid bipedal robots. We have a new app being released soon that uses 2 additional servos for hips. That helps JD walk a little straighter.
Thanks for the reply.
However, I think the servo is bad. I tried calibrating (after first manipulating the joint out of 90 degrees), but it does not move. Also I lifted JD while he was walking and that ankle does not move like the other.
@hihuq, click on the Product Warranty button in the Contact Us section and fill out the email form to send your issue off to EZ Robot. Their service department should be able to get you another servo rather quickly.
For some reason when you click on the Technical Support button it sends you to this Forum . I know that can be frustrating but most of the time the people here can get your issues solved faster then the guys and gals at EZ Robot. cool
Thanks Dave.
I've tried the contact us/ product warranty button, and filled in info, a couple of times now. Every time I try to submit, it comes back with an error.
What does the ERROR say ?
What Error? What is it saying?
A couple things you need to do:
Are you doing the Human Verification at the top? Is your email correct and the same one you signed up with? Did you select a choice from the drop down menu for a Warranty Reason? Also make sure your clicking the box at the bottom that your not asking for tech support.
Its a generic error. Link is https://www.ez-robot.com/error.aspx and text is as follows:
" Error!
Now look, you've gone and broken something!
Just kidding - it's probably our fault. The error has been logged and staff has been notified.
If you think there has been a mistake, or you need help, please contact us. "
I've done the human verification, email is correct and consistent with my sign up, drop down menu warranty reason selected, not asking for tech support box is checked.
Occurs with both metro and desktop versions of IE.
Try switching to another browser like Firefox or Google Chrome or Safari.
