Omron HVC-P2 icon Omron HVC-P2 — Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition. Try it →
Question Editing Frames
I get a "unhandled exception" error whenever I try to edit frames. I am using a six with claw robot. I can see all the servos in the settings but error occurs when I select any frame to edit. I can see servo positions for all legs but no claw servos. The actions I already had such as arm up/arm down still work but I can't edit or add new frames involving the claw. Tried rebooting and updating windows 8, no luck
I did recently reformat PC and fresh install of ez robot, then loaded robot from EZ cloud. I also added many actions from the regular six robot to my six with claw using import/export function and I suspect this is where the error occurred. Any suggestions?
Can you add a screen shot of the error?
Screen Shot Directions: Pressing the Function and PrintScreen button the keyboard together will take a screen shot. You can then open Paint and paste the screen shot in, crop the image as needed (if needed) and save the image to attach it.
Sure, here is screen shot
Nice protect is it from windows or ARC
SYMPTOMS Some valid C code may compile correctly, and then may not run correctly. When you run the application, you may receive the following error message: Unhandled Exception: System.InvalidProgramException:
Is this your problem:D:D
Again saying it is a guess
I don't think it is .net issue. It does the same thing on two computers. If I load old six with claw project I can edit all servo frames normally. It is specific error related to importing all the frames from regular six project (which has a lot more movements) to six with claw. It actually works great....because doing it like this it behaves how I want. For example, movements ignore the servo arm leaving it in the position I already had it in. The problem is can never change it without reverting back to just basic frames/actions of generic six with claw project.
You can't import the frames from a six project because it's a different number of servos. Either modify the six project or modify the claw project. Cannot merge the two with different number of servos.
