Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
Germany
Project Backup-Question
hi @ all,
when I save a project and open it again, there is a problem:
  1. the camera grid is in a wrong position, not in the default position.
  2. the blinkM window is reseted and I think a lot of more current settings are not saving. its a lot work to change all settings after I open my project
regards Marty
Thw camera grid issue has an existing bug report and is on DJs todo list to fix.
BlinkM I think is a newly reported isssue though.
I believe by resetting the OP is talking about smart arrange. The fact that the controls move into sorted position when opened.
Disable smart arrange when opening a project. This isn't a bug, it's a feature.
Every single setting is saved - and it's impossible for a setting to not be saved. This is due to a programming feature called reflection that I use. Reflection converts the configuration override of every control to a serialized xml object. It's impossible for a parameter and attribute to not be serialized.
Germany
I disable smart arrange and the grid, soundboard volume, blikM are in a reset position after loading.. thats what Im talking about: https://youtu.be/dWZ47zOHnGM
Yes, we are aware of the Grid as mentioned. It is on the list of items.
My response was regarding the "resetting positioning of blinkm control". Please re-read my response to understand the blinkm resetting placement issue that you have experienced. Disable Smart Arrange for blinkm to not be re-arranged.
You must resave when you turn smart arrange off, and arrange you windows again. Is the blink m control resetting completely or just moving?
Germany
thanks for the reply DJ.
@ Technopro after I resave and open it again all blinkM-Options in the blinkM Window are reseted to 0
regards
Germany
question resolved
