Ok dc to dc converters can allow us to drop a battery voltage saaaay like a 7.2 v rechargeable down to the 6volt the servos and ezb need. Motors can handle a little overvolt sometimes. This is useful for dropping voltage for lights and LEDs too so your not wasting lots of power through tons of resistors. In my case I have a 12v motherboard and everything else runs lower voltage so the motherboard PSU goes straight to 12v and everything else is dropped to 6v as seen in the picture. Dc to dc converters range from 2 to 10th dollars on ebay. I opted for the nicer one with built in led display to show both input and output voltage which.is great for setups and trouble shooting without using a meter on every connection. Dc to dc converters are up to 96 percent efficiency meaning 4 percent is lost through heat.
jstarne1
— Edited
5 Participants
That's were I bought them!
shipping takes three weeks though.
Thanks, I was wondering. I will be using a few of these for my big bot.
@jstarne1
Yeah, i order a lot from china/japan because all of the parts here in Dutch stores are usually more than 4x the price. I'm used to waiting that long for them to arrive.
i found one very small $11.25 ,little bigger then regulator 5 volts out at 2 amps
5 volt dc-dc converter
