Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
no only a little black line appear below under taskbar
If you launch notepad, you have the same issue in that application, correct?
i set resolution lower ,then i have this.
thank you RR
d-cohran your wright same in notepad
set your resolution back.
If you launch notepad, you have the same issue in that application, correct? what is the brand and model of your monitor? I will see if there is a resync or auto picture adjustment in the menu or anything like that.
#16
do you know the model number of the HP? I am going to look online for the menu options.
