does these ports have ID,?i wanna use two rgb's
— Edited
3 Participants
SSC-32 Servo Controller V2
— Bridge ARC to Lynxmotion SSC-32: maps V0-V31 to SSC-32 channels for reliable, high-performance serial control via USB, EZB/Arduino UART.
Turns out i forgot to save it in ARC. The code was there, but no button to use it. Haha
I have added the Change i2c utility for the next version of ARC - which will be this evening.
dj you work fast as lightning.
thank you.
where can i find the adres of a rgb ? standard is 0xA0
problem when i take a second rgb window and try to change the adres,the , ezbv4 disconnect.i wanted to use two rgb as tail lights on roli.
this was an old topic.but solved.
thank rich
i made victory to early.you can change the adres.but here's a problem. best to use one rgb at the time to change an adres.taking a second one, causes a problem,you need to close and reopen ARC to validate the adres. so you need to save your project with two rgb els the ezbv4 goed into lock up. and thats when ezb or rgb gets confused.it works for about 45 min, then one rgb goes out.then you need to start from the beginning, to get bolt of them working again.with original adres.
