@DJ Sures
I am so glad to see the EZ-SDK update.
Last time, you told me you would complete the image problem for Parrot Drone 2.0. Can the EZ-SDK work for that?
Thank you so much
Dual Hbridge
— Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed.
@DJ Sures
Thank you so much
AR Drone 2.0 is good if you mount an ez-b V4 in it with camera.
The weight carrying capacity of the AR drone is pretty limited (Parrot says it is 0, but people have successfully carried GoPro cameras with some stability loss). I am sure it could carry the EZ-B and camera, but not sure about the battery too.
True, but maybe Ez-robot could make the first ar drone with extra propeller for weight lifting!
