EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Hello dustin:)
You'll find the manual for the HB-25 here: https://www.parallax.com/Portals/0/Downloads/docs/prod/motors/HB-25MotorController-V1.2.pdf
The description within the manual explains how it works. Read the manual, and also follow the EZ-Robot Tutorial Section to understand more about Servos and Modified Servos, etc..
Quote:
The HB-25 connects to the microcontroller much like a servo. You can use an extension cable or a custom cable to connect the HB-25 to your controller. Reversing the M1 and M2 connections to the motor effectively reverses the direction.
Simply connect the HB-25 to the EZ-B with a shared ground and servo/signal and you're off to the races:)
In ARC, use either the Modified servo Control (for one motor) or Modified Movement Panel (for two motors) - depends on your setup.
