Wheel Encoder Counter icon Wheel Encoder Counter — Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS. Try it →
Pandorabot Config Crash
Release 2013.03.11.00
PandoraBot UI.
After opening the new PandoraBot control, I selected the config button. I made no changes to the config and closed it using the "X". The following error message appeared:
EZ-Builder forced a shutdown of the application.
I reopened, then added a PandoraBot control again, but I "Paused" the control. I opened up the config and closed again, this time no crash.
So, it appears that opening the config while the control is running causes an application crash.
It works OK for me, or it did on a quick test I did with the confidence right down low.
Which leads me on to ask about the confidence level. It will say in the box the confidence level after you speak, make sure this is above the set confidence in the settings. Be aware that a low confidence will result in more odd responses though.
Well I'm struggling with it never had a response
I get these errors and no response from the EZ-B example
I can go onto the Pandorabot site and have a published bot on there that I've been training and the responses work well
About to try another machine as I suspect my works VPN
Well works great on another machine.
If you ask who is your master the response is 'I obey DJ Sures' )))
So VPN issue for me
On mine it recognizes what I say and it shows up in the window but the response does not show so nothing gets spoken.
When I type my question in the box and click on the send button it displays the correct response and also speaks it out loud.
Is there some other config screen in ARC I'm not seeing or maybe something I need to change in Windows? I am running Windows 7.
That's a strange one.
There is only the one config in ARC where you set your bot, your confidence etc. Windows 7 settings shouldn't be the issue either if it's speaking when you type.
Have you tried a new project with nothing but the Pandora Bot control added?
Hi Rich,
How do you setup your own Bot I notice your username is Rich and DJ's is DJ. So are we all sharing the same bot? as the Bot Id is ea15c82aee345ded
I created my own bot and published it picked up the id from the published html link then added it to the EZ-B control and my Pandorabot id which is my email address and I get bot id not found?
I clearly dont understand something
Hooray got it working when I cut and paste the Bot id from Pandorabot it added a space which needed deleteing now My EZ-B has its own bot and unique responses
#16
The bot ID is the thing you need to change to use your bot. Username is not going to make a difference as far as I know...
My bot id is f5856abb0e345d1d with my new bot, feel free to change the id in ARC and ask it his name. It should reply with something different to the default...
Set up your bot, and publish it. Copy the ID from the end of the URL for your bot... i.e. my bot is at https://www.pandorabots.com/pandora/talk?botid=f5856abb0e345d1d
So bot id is the f5856abb0e345d1d part.
I've only briefly played with the control in ARC though. I'm not sure what the username does, I've never used one with Pandora Bot...
