Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
If you have something worth adding to sdk then past in the code and purpose. If its a good idea it will be noticed. Development of ez robot software is influenced by the members building robots and sharing ideas. - Josh S
The EZ-open bot is open source I believe.
Other than that, as has been said, make the suggestion and it may get added.
What features are you thinking though? It's already pretty powerful and flexible.
