Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Network Question:
Ok, here is what I have:
The ports are: Router 10.0.0.1 Desktop 10.0.0.2 MagicJack 10.0.0.3 EZB 4 (Sally) 10.0.0.4
I have everything going into the router and then going to the Internet.
I have two wifi connections. One is for the Internet and one is for the EZB. If I hook up for the EZB, I loose the other connection.
I guess my question is: How do I hook it up were they are BOTH connected?
The ports are conflicting.
OK, so I found a USB hub and an N type Broad-com WiFi adapter.
I hooked it all up and it installed the drivers. They all went in fine. I had to search for a place to tell it to hookup to WiFi.
When I connected up to it, It kicked off the other WiFi connector. And when I hooked the other up, it disconnected the previous WiFi.
My batteries are almost dead now, so It will be Monday before I can test it again. And do the procedure outlined above.
Thank You for all of your help.
MovieMaker, please don't create duplicate threads:) you have the same question asked yesterday here: https://synthiam.com/Community/Questions/7786
I answered your question in the other thread. Did you read the answer? Did you try what I suggested? What part of my response is giving you trouble?
I was talking about networking in the second thread. And I was talking about hooking up the V4 in the first thread. I did not realize it was asking the same question.
I went through the steps that you laid out and I got the V4 to work just fine with the V3 working also. But, I did not quite get the networking part of it with tightVNC.
Sorry. blush
Ok, I changed everything to client mode. But, I still cannot hook to the net while hooked to the ezb4.
I have my desktop going to the router and then to the internet. I have two wireless connections: Home-4F92 and EZ-Bv4 07C8. When I connect to the EZB connection everything works on the W3 tablet. But, I cannot use the Net. I have to change connections. The problem is, it is very hard to take the tablet off of the robot and make the change and then change it back again later.
I have it in client Mode.
Please, Help!
What colour is the led on the ezb4 when it boots up... Green or Blue?
#15
Blue
I have tried the procedure 100s of times. I am trying to get into client mode. The ONLY way to do this is to turn off the internet.
It is an Xfinity router.
#16
That's what I thought.... @Mel, blue means you're still in WP mode... You are NOT in Client mode... Client mode is indicated by a green LED... I would suggest going back to the videos that DJ posted and view them over again... Again follow the videos religiously.... Keep it simple, one step time... This is very, very simple if you just follow the videos....
