Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
LinkedIn Twitter Google+
Need Help With Jd-Bot Connection
trying to control a jd-bot from a Fujitsu tablet, but ARC says cannot connect to ez-b. Bot is working fine, can control from my dell with no problem.
Any clues what to look for?, have removed AV software just in case (was mcaffee- ugh)
thx Paul confused confused
Make Tablet is connected on the same Wi-Fi network as EZ-B V4. Check the IP address on your tablet, make you it is the correct one, match the one with your dell PC.
You can also check out the Tutorial https://synthiam.com/Tutorials/Lesson/15?courseId=5 on how to connect it to AP mode or client mode. Also have you try resetting the board?
have tried both solutions, looks like it may be time to try a usb dongle - any recommendations? Thanks guys.
btw DJ. we are live today and tomorrow at the Education Innovation Conference in Manchester, UK the bot was probably the most photographed thing during setup day:)
Paul! That is great news! Please share:)
I'll be sure to tweet later
Hi Guys, All fixed, it was a subnet issue, devices were Fujitsu internal use and for some reason are set to 192.168.15.x rather than the more usual 192.168.1.x once they were changed, magic off they went.
