Vader Sentiment Analysis icon Vader Sentiment Analysis — VADER sentiment analyzer for ARC returns positive, neutral, negative percents and a compound score from text; enables emotion-driven behaviors. Try it →
My Ez-board Just Went Pop :(
My Ez-Board Just Went Pop :(
Man,
I just though I'd have a play with my ez-b having not played with it for a while, but when I connected the battery, nothing happened. Removed the power and re attached it a few times when it decided to just go pop:(
Anyone any idea what happened? And whether its repairable? Really can't afford another one at the moment:(
Matt
@ Matt yup Omnibot center pin was neg , when I did the accidental power reversal I used the omni power barrel connector too. Just goes to say, check that bad boy with a meter when in doubt lol
Hmm, what does a flashing blue led on the main board mean? Got power attached, and the led is flashing, but can't seem to connect to it.
The blue flashing LED means it has power but not connected to your laptop through Bluetooth. Once it connects to ARC this LED will stay on steady. In the center of the board you should see a small red LED on top of the Bluetooth chip that is also flashing. Once connected that one should also stay on steady. Are you seeing the red LED?
Hmm, no, just the blue one. That mean my Bluetooth module is shot?
I cant say for sure but it doesn't look good. Maybe a e-mail to EZ Robot support is in order. They may be able to sell you a new one if it is bad. I know there are other modules for sale that work well with EZ-B and have better range. This may be your chance to upgrade. Do a search on this forum to get those units and how to hook them up.
Ireland
Have you disconnected all servos ets
@Bravia, yea, there was nothing connected.
@dschulpius thanks, I'll drop support an email and see what happens. I may convert it to wifi if it is shot.
#16
That cap is mostly for filtering the power supply,if there is none it not filter right,really hard to tell unless i look at the circuit But without should be ok
i would check the 5 volt line going to your bluetooth to see if its good
Hevent had the time yet to reverse engineer it and draw the circuit up,i can tell you more about it
Since designing and making battery power circuits is mainly what i do at work
