I watched DJ's video on how to wire it up.
I think I can handle that.
Wanting to know what size speaker (ohm/watts) to use.
Script Monitor
— Monitor and diagnose running ARC scripts: view active script labels, statuses, and stop long-running or background scripts easily.
I run mine through a Sure 2x25 amp. I couldn't find speaker specs in the MP3 trigger documentation.
Also use a Ground Loop Isolator to protect you MP3 trigger if using any cheapy amp..
Certain amps back feed V+ and have been known to pop/fry MP3 triggers.
I put an 8ohm .1w speaker it work but you have to struggle to here it
What did DJ use?
I used the speaker from the Wall-e
The MP3 Trigger documentation might mention what ohm/wattage speaker to use. Those little speakers seem to work fine for me
OK
thanks
I just purchased a 8ohm .5w should be a little louder
