Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Resolved Resolved by VGosine!
More Information On Features
would it be possible to get some more information on motion tracking and pandora, i would love to see a example script using these
Examples im looking for are a motion tracking script where you can tell the robot to follow an item and it will and a video on the setup process for pandora
also is there a way to pull one project into another so i can use an example script as part of my current project
sorry, i have been making a list all week
With motion tracking and following you need to be careful not to track the robots movement too. If the robot moves it will see motion as the image from it's camera will have changed. Every control has a ? which will take you to the help page for that control. There are also mouse over help icons on the controls which explain each item. To follow motion you just need to enable motion tracking in the camera control and enable the camera control to control the movement of the robot in the camera configuration. As for Pandora, this is a third party service which EZ-Robot didn't have any involvement in. The control was added as it was requested by a few people. Pandora's website has information on how to set up your own bot and is the best source for help. There is an example in the examples folder of ARC which gives some additional information on how to use the pandora control to move servos and use script commands, this is most likely the most help EZ-Robot can provide on the control.
Yes. Use the Merge function. It's in the file ribbon next to Open. Click on it, select the project you want to import from, select the controls from the list that appears and they will be imported in to the open project.
Trinidad/Tobago
Twitter YouTube
Hi you might be looking for the example scripts and usage, when on the examples tab of opening a new project there are two folders that begin with EZ-Script that you should check. Example Projects - ARC
thank you for all the answers i will look into it all, sadly the example folder keeps coming up as missing since i updated and i have not had a chance to fix it but i have been using the online copy so i will look there
Trinidad/Tobago
Twitter YouTube
There has been a new update of ARC since that bug occurred so it should be fixed with all of the examples once you update.
i wish it was fixed but i update daily and had the issue a few hours ago when i was working on the robot
The example folder is saved in Documents\EZ-Builder\Examples
If it is coming and going as you say it is then you have some very strange issues with your PC.
I'm not sure what you mean by the online copy, there is no online copy of the examples...
