Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Resolved Resolved by VGosine!
More Information On Features
would it be possible to get some more information on motion tracking and pandora, i would love to see a example script using these
Examples im looking for are a motion tracking script where you can tell the robot to follow an item and it will and a video on the setup process for pandora
also is there a way to pull one project into another so i can use an example script as part of my current project
ow then i have never seen them i thought everything was in those examples online like the one i made advanced robot, and i have looked there and the folder does not exist, i have 6 folders includeing my projects but no examples folder, is there somewhere i can download these?
i never got a chance to go throught the exmaple folder before the update caused the program to say the folder was missing as an error window at which point i checked for it manually and just rechecked where you said and its not there nor was it when i checked after the update
Trinidad/Tobago
Twitter YouTube
The example folder is created and populated every time you install ARC, there was one release where that folder lost the project files in it, but it has been fixed in the newest release. If you seem to be having the problem even after updating to the newest version, you might need to completely uninstall the program and then install it again.
that solved the empty folder problem, thanks
