Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
THERE might be a way to write in sdk and use ARC i will asked my programmer expert i on this
PLUS DJ said something awhile back on how to use arduino code in ARC and using I2C buss to connect to it. I did find a bluetooth with a I2C BUSS and mindwave does use bluetooth ,plus it might work for other interfaces that need a TX and RX interface.
Second i found a arduino for mindwave that someone is using to control a wheelchair ,its from the mindwave sdk site so only need to make EZB code with DJ IDEA
THANKS for your answer RICH ANYWAY
that would most likely be modifying the software. AKA hacking it. Not that i'm against it, but it could make ARC unstable and cause problems.
Reverse engineering, or modifying the ARC software is against the terms and conditions of use, although that isn't what he is attempting.
I know RICH you cant modify the ARC DJ said how to convert ARDUINO CODE to EZB code to use less lines,it was on a spectrometer design i made using 7 digital I/O and 1 analog port ,he came a part of the code in a EZB script.
Thanks for correcting TECNOPRO AND making him understand what i am saying
Wow, re-read my post, I clearly said that it isn't what you were saying.
I trust you will edit that post once you realise you have it completely wrong?
Also i think BRAVIA is trying to make it work with PYTHON on another post about it
#16
Check your link, it is incorrect and does not point to anything related to the mindwave or Bravia.
I assume this one is the one you mean.
