Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
I don't have a mindwave but mine does the same thing, so it's not just your PC.
Ireland
Thanks Rich
VERY happy to see DJ add a interface for the mindwave and hope he add interface for EMOTIV EPOC eeg headset I bought both ,on mind wave it only uses one EEG sensor on the EPOC is uses 11 EEG sensors for $20 more.
DJ, is fixing this still on your todo list? Like the AR Drone 2, I am interested in buying one of these but want to make sure it will be supported in ARC before I spend the money.
Mind wave doesn't work. It will be removed in the next release - thanks for the reminder:)
Then I will not waste my money. Thanks.
ALAN dont give up ,i asked a friend thats a programmer and is is looking at EZ-SDK to make it work with ARC
The SDK is a replacement for ARC. You use one or the other not both.
