Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
@Smick, quick answer is no, you will need to write your own scripts to control your servos. Get yourself some popcorn an adult beverage or if you're underage your favorite drink take about an hour watch the video(s) and you'll be writing scripts in no time.
Here is a link to tutorials, https://www.ez-robot.com/Tutorials/
:D
Also, for questions like this you really don't need to use the assistant required just a General discussion. Cheers
Oh, and you don't need to write scripts... simply use the Auto Position control. It's super easy, and it looks like the AI bot also replied with useful links.
The jd project has a different configuration and more servos than your robot. So using the Auto Position control allows you to create animation frames.
Here's a direct link which includes information videos and text details on using the Auto Position control: https://synthiam.com/Tutorials/Help.aspx?id=180
Yeah cheers , I have a full unit coming , The one I've been using before this lotiny wasi the ssc 32 , I'm feeling the change to ez robots will give me more freedom . It's funny I only got into the robot thing a couple months ago for my 8yr old step son to learn coding and robotics , $2k later I'm hooked lol
Smick, sounds like you'll fit in well around here! It's a safe addiction, that's what I keep telling myself:D
