does the use of long wires drain the batterie ? i have two new batt drain fast and charge fast.
— Edited
EZ-Script Console
— Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
No Nomad.
Yeah - longer wires will add resistance, and be more noticeable with motors or anything drawing high current. However, how long are the wires? Because adding a few inches won't make a difference. You'd have to add a wire two or three times the length.
For example, using servo extension cables will reduce battery life because servos use quite a bit of energy.
Also, a thinner wire will be much higher resistance.
It must be a very long wire Dj, and i dont belive that Nomad's robot has 20 meters of wire.
i use 3 extention cables each servo.
