hi
am looking for to let a script keep running whithout stopping. cant find it
anyone thank you
EZB Connections
— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
hi
anyone thank you
ah thanks david.
Or in blocky, use the LOOP command titled LOOP FOREVER
It generates this code...
dj
is that only in the begin ? loop forever or is there at the end also a command.
The above code loops forever... If you want to stop the script use the command below or to just exit the loop but stay in the script you can use a different "Goto/Label" command to put you outside the loop...
thanks averyone.
This demonstrates both ways to exit the loop or script in blockly.
Use Blockly to learn how to program
