Picture In Picture icon Picture In Picture — Picture-in-picture camera overlay: superimpose one camera onto another; configure source/destination, position, size, border, processed frames, and swap Try it →
Joystick Control
So I have built a small tracked robot running off a h-bridge and am running two DC motors to drive it. I started of with the h-bridge Movement Panel and it worked fine, I then got a wired controller to run it and the robot will move around correctly using the left joystick( using the default setting). My problem is I want to use the second joystick to control the vertical position of my camera which is mounted on a servo, but I cant seem to get it to work. I have configured it to use the appropriate port, D1, that my servo is hooked up to but no go.... any suggestions? Also I cant seem to use the d-pad, it doesn't seem to recognized them.
Some joysticks do not support the dpad and analog to work at the same time. There is a button on the joystick which selects between the two.
As fror the second analog stick on your joystick, if it's enabled, it will work:) Simply select the ports.
Do you have two analog sticks on your joystick?
Yea I had a ps controller like that, this one however is not. I have all the settings on the 2nd analog stick enabled correctly but i just discovered that instead of the right joystick controlling the up and down movement its the right and left triggers. And it wont even recognize the d pad in the config setup ...... yea im stumped
Ps...... I'm using a wired 360 controller
