Jd Ezb Losing Power Connection If Bumped Or Jolted
I was very fortunate to pick up a used Six and a JD from Ebay for $350 total. The kits are in good shape. My JD robot EZB appears to be disconnecting from the battery if you bump the EZB or it does a move that jars the robot too much Is there some trick to keep it from disconnecting? Can the EZB be removed and re-seated into JD's back?
Right on @mstephens_42
Nope, double sided foam tape is definitely not from the factory.
Pin adjustment worked great! No more disconnecting EZB!
